Sanjin Jukic
- Dec 28, 2006
- Vienna, Austria
- www.sanjinjukic.com
Four Thirds for 3K on RED
If somebody could design Four Thirds lens mount on RED that could be
useful MAYBE in 3K RED mode because all those lenses are strictly design
for digital sensors.
RED 3K: 16.59 x 9.33mm
Four Thirds: 17.3 x 13mm
"The name of the system comes from the size type of
the image sensor used in the cameras. The image sensor is commonly
referred to as a 4/3" type or 4/3 type sensor. The common inch-based sizing
system is derived from vacuum image-sensing video camera tubes, which
are now obsolete. The imaging area of a Four-Thirds sensor is equal to that
of a video camera tube of 4/3" diameter.
The size of the sensor is 18×13.5 mm (22.5 mm diagonal), with an imaging
area of 17.3×13.0 mm (21.6 mm diagonal).[2] Its area is 30–40% less than
the APS-C sensors used in most other DSLRs, but around 9 times larger than
the 1/2.5" sensors typically used in compact digital cameras (see image
sensor format).
The Four Thirds system uses a 4:3 image aspect ratio, in common with
compact digital cameras. This differs from other DSLRs which usually adhere
to the 3:2 aspect ratio of the traditional 35 mm format. The Four Thirds
standard specifies the aspect ratio in addition to the size of the imaging
circle. Claim 1 of US patent 6,910,814 (mentioned earlier) is specific: "…said
camera body having an image pickup device having an imaging range with
an aspect ratio of 4:3 on an imaging surface within the image
circle…"
Four Thirds Lenses>>>
About Four Thirds>>>
About sensor sizes
sensor format).
circle…"
About sensor sizes
