Sanjin Jukic
- Dec 28, 2006
- Vienna, Austria
- www.sanjinjukic.com
An important issue about using still lenses... we are shooting "Moving Pictures". Still lenses are not designed for follow focus. If the subject or the camera is moving, (which it often is) then pulling focus is a serious issue. The whole point of T1.3/1.4 lenses is the depth of field. If you are shooting wide open and trying to keep a moving focal plane in focus, believe me, you do not want to be stuck on a still lens not designed for follow focus.
The best lenses: Zeiss Super Speeds T1.3
They are have a PL mount and a set of 5 (18mm, 25mm, 35mm, 50mm, 85mm) lenses rents for $300/day from most rental houses.
Don't worry, with still lenses you can shoot a graet movie. It is all about your cinematography style. Getting more expensive lenses and cameras will not you make a great cinematographer at all. Read more about cinematographer style at the VITTORIO STORARO's trilogy 'Scrivere con la luce/Writing with Light' [1. 'La luce/The Light' (2001), 2. 'I colori/The Colours' (2002) & 3. 'Gli elementi/The Elements' (2003)].
