Sean Michael Johnston
I am wanting to process multiple clips in Redcine and output individual QT files. When I start the process, it works fine for the first 2 clips, then I get the single frame for the entire clip problem for the rest of the shots in the sequence. It's repeatable and if I babysit, I can cut off the 2 processed clips and keep starting over. Obviously this is not an optimal workflow.
Has anyone had this problem, I couldn't find anything by searching the threads.
