You'll need to pick up a mount adapter (I advise Les Bosher's[FONT=Arial, Helvetica, sans-serif] Arri PL - Arri Standard with Spring loaded levers)[/FONT]
Any idea what that might cost?
Thanks, Chuck! Well - 'poor' is spot on and as for 'bastard' - I've been called worse - even by the trouble & strife.
Any thoughts on Angenieux in general? What sort of reputation do they have?
I know I'm a real lens klutz. I proved this last night - I did some calculations for DOF and came up with a hyperfocal point of 33 meters at the near end of the lens. Call me old fashioned, but isn't that a bit high? Or am I missing something somewhere?
Cheers, Phil
About £200 - £250. $400 - $500. But they are very good quality.Any idea what that might cost?
It's not enough for the image to just cover the sensor because if the rear element is too small and too close to the sensor light will hit it at too oblique an angle for all the light to register. This is a limitation of CMOS sensors and isn't an issue when shooting film.
This has probably been mentioned elsewhere but test for portholing before buy anything..
Hi Phil,
Angenieux was and is one of the primere optical companies in the world. Their Optimo are right up there with any thing made. About your hyperfocal split at the near end do you mean the shortest focal length?
Also I think you can mount an afocal attachment that Angenieux use to make for your lens and it becomes something like a 12-50mm or there abouts. Ask Derick he will know.
I found one and guess who has it.
http://cgi.ebay.com/NOS-7-X-Retro-a...ryZ30077QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I've seen them on ebay go pretty cheap sometimes.
cheers
Well, yeah, and their HEC stuff is great. But their older 70's-era zooms suck like a teenager whose milkshake straw is too small. The 9.5-57 is a horrible coke-bottle lens and the 12-120 is barely any better. So when you talk about Angenieux, there's really two different Angenieuxs to consider. The older stuff is not on par with their modern lenses.Angenieux was and is one of the primere optical companies in the world. Their Optimo are right up there with any thing made.
Hi,
Yes I have been mentioning it here & elsewhere for many months. Most people have ignored my comments on the 16,24 & 35 Zeiss Standard T2.1's.
Stephen
This has probably been mentioned elsewhere but test for portholing before buy anything. I just shot some lens tests with Red#98 and Stephen Reizes in Toronto and portholing is definitely an issue with older and newer lenses. It's not enough for the image to just cover the sensor because if the rear element is too small and too close to the sensor light will hit it at too oblique an angle for all the light to register. This is a limitation of CMOS sensors and isn't an issue when shooting film.
Just don't want someone grabbing a c-mount 12-120 dogleg lens for $200 and sticking it on their Red One and seeing it look like a VHS camcorder and saying "but... but they said Angeiuex was good!"
Modern Angenieux = wonderful. Old Angeniuex? Made for news. Let the price tag be your guide.
Actually the 9.6-57 is a very nice lens.
Hi Phil,
That's actually 9.5-57mm I can't type for shit.
15x10B means; The widest focal length is 15mm and the zooming range is 10 times that so it's a 15-150mm zoom. The B means it's a lens without a side finder. An "A" type lens would indicate it has a side finder and a "C" type would be for a Bolex Rex. As for why it's 9.5mm I guess that's as wide as they could go within the design parameters.
Phil!
Buy you books and buy you books and all you do is eat the covers. LOL
The shortest focale length is 9.5mm and the longest is 57mm.
If it was a 12x10 it would be a 12-120mm zoom lens.
Get it?
