- Thread starter
- #21
Kevin Halverson
Hi Mike and all,
I will look into this a bit further, but I really want to finish up the FD mounts first. We will finalize the order with our vendors on December 10th and I will have a bit of time right after to look at a Leica solution. I am not really worried at all about any of the "complex machining" as none of this is really much of a challenge to our guys. They do all sorts of tiny moving precision parts all the time.
What may be overlooked in the "dummie flange" concept is that it isn't a flat surface that you can just mount an extracted mount to. Its recessed and very precision so the mount has to match the flange to reuse any of the pieces we have developed. The adjustable FFD feature is simple but necessary as far as I am concerned. Even if your mount is perfect, don't assume that the sensor plane is exact in relationship to the body.
The number of 25 pieces is a good minimum, less than that and the setups get amortized over to few of pieces.
Give me a bit and I'll try to have some firm answers to what, when and how much.
Thanks,
Kevin
Thanks,
Kevin
