Ed van der Kruijssen
- Jan 25, 2007
We made two schemes with possible workflows one based on uncompressed DPX HD/2K/4K and one based on Pro Res 4:2:2
For cheaper: just cut the offline QT files> EDL > RedCine (coming soon)>dpx>After Effects
This is pretty much my dream workflow. Is it actually possible? Will the EDLs work in Redcine?
So if I'm to understand correctly, I can't make my El Mariachi in 4k with my few thousand dollar MacPro setup with FCS2... I'd need to offline in that and then conform in some crazy application afterwards... Is that right and not something I can get around? What is the workflow for after effects?
Would be a shame if we have to finish to 720P or 1440X1080 DVCProHD just because we can't figure a workaround to get our edit back to the glorious 4K we started with.
Thanks dip.
I don't mind if I have to finish NOT in realtime though...
If I can cut my movie using the 1k or 2k proxies (or whatever I happen to use)... in FCP
then use the EDL and piece the film back together in a program like colour? Would that work? It wouldn't be in Real Time, but I could possibly work out my colour grade using downrezzed files... and apply the grade to the full 4K files...
I'm just trying to work out the full Mariachi... Even if it means a week of rendering... or even a month! If it saves thousands of dollars in onlining costs.
It would be a tedious workflow and obviously avoided by anyone who could afford to do it a better way... But still... Red is opening doors to some of us who have no right to dream such dreams... Would be a shame if we have to finish to 720P or 1440X1080 DVCProHD just because we can't figure a workaround to get our edit back to the glorious 4K we started with.
stay tiger (no leopard just yet...crashes prores)
load new fcp patch 6.02
load new redcode codec
open an hdv-prores 422 1080p24 project from easy setup
set playback video quality to medium
set unlimited rt
drop 4k file as the first piece of content into your timeline (e.g. drop a 2k proxy into your timeline first, as opposed to a 1k proxy from a 2k shot)
then you can drop anything 2k, 1k high fps into the timeline and it will autoconform and playback without rendering.
now if you do crazy effects or lots of extra stuff, you will have to render it out.
this is the newest most efficient workflow in FCP that will avoid you having to render to have playback right away.
what provides the seamless playback is the combination of the new codec, the original timeline settings, the new fcp patch, and the first piece of content brought to establish the "real" project properties.
redcode is only a playback format, you can not write to redcode right now. so if you want to mix and match 2k and 4k clips without having to manual resize and render, this is the combination that works.
it allows the content (4k, 2k varispeed) to be autoconformed to playback in real time. you must have a system with a bit of muscle, but it works great.
i did not create this formula, i got it from the guys at plastercity yesterday where they are working on the new RED Reel.
and when i said 4k file, i meant to say 2k proxy, versus a 1k proxy...
clarification when you shoot 4k you create 2k "H.mov" files, when you shoot 2k, you create 1k "H.mov" files. so they look the same in the finder, but the 2k h.mov is clearly different than the 1k h.mov, the physical size is different and your ability to play it back is different.
this combo allows you to playback and fcp does the resize automatically for the 1k files to the 2k size.
the 1k h.mov files will have black pillarbox on each side as the actual aspect ratio is different. but it is very close in size.
it does not run at full playback on my On-Set iMac, (unless i render and it is a 4:1 render time on a 2.8ghz, 4 gigs of ram new 24" iMac") but does on a 8 core tower with 4 gigs of ram.
Thanks dip.
