The files the Viper and F23 spits out are dpx files. We are recording to S2 hard drives.
Research has shown that if you're going to compress a digital image, the "best" place to apply the most compression is as near to the start as you can. At that point, least has been done to the image that can cause the compression to be less efficient.
Graeme
I'm not nitpicking, but the Viper and the F23 output video streams - in your case, 4:4:4, RGB dual link video. .
Yes, NR can make an image more compressable. What the research was, and I think I heard about it from a BBC engineering contact, was that doing the heaviest compression at the end, for delivery, was, theoretically, the worse place to apply it. Applying strong compression at the head, with the cleanest signal, was preferential. Of course, this is a "general" thing, and some post production can make an image more compressable, whereas a lot of things can make it worse.
We're in a slightly different game as we're dealing with RAW sensor information, and I think we have shown that a reasonable amount of compression at the head of the chain can be done very well.
Graeme
Hi claudio
I sure see nothing wrong with those Blacks :
But I'd like to know what someone of your experience would be looking for in those blacks.
here's the colour correction done AFTER compressing in jpg quality 1
Here is a DPX file that is about as full range as I can find. It will appear very flat, it has almost no correction applied, only a small bump in brightness and little bit of highlight retention.
Since my posting on this site, it looks like I am getting my tests.
I think it is being read the wrong way by those that are not familiar w/ the source
It is not about blacks hitting zero. A jpeg does a good job with that. The files I get from the Viper/F23 look pretty flat so the image is very malleable. The more dynamic range I have, the more chances I have of bringing down a blown out sky or lifting something out of the blacks.
I did open your file. I discovered no new information in the blacks.
Here is an example:
http://www.claudiomiranda.com/heinekenttl.html
