- Banned
- #1
Okay, Now a seperate question.
If I ordered by Mid-January would my cameras be ready by Mid-Feb. or March?
We're shooting each set with 4 cameras. 4 angles @ one time.
Throwing twice as many cameras at a script does not cause it to get shot twice as fast.
You may see a 20-30% time savings if you are really on the ball, but even that would surprise me.
IMHO I would see a 20% slow down with running that many cameras not to mention how much more it would cost to shoot outfit all those cameras.
Your typical feature main unit has 2-3 full camera crews and equipment and maybe 2 spare bodies on the truck in case of problems. Generally everything is shot with 1-2 cameras at any given time. This is because experienced people have learned this is the most effecient way to shoot. Except for a stunt or explosion over 3 cameras working just becomes a Cluster F#(^ of problems.
The way we're lighting is we are setting a base lighting style, that won't change.... and then depending on the shots we'll add some low powered lights to fill anything we need to.
We're building the sets completely inclosed , but they have a bar going through each flat allowing them to swing up.... so we can have 4 walls, and then swing up a section of the wall to allow the camera to get a shot into the set..... then when we need a reverse, we just bring that part of the wall back down, and do the same thing on the other side. It would be main frame, with bar from one side to the other, then each flat is basically hung from that bar, so the flats can free swing.
There are also alot of steadicam moves, so we got a bunch of cameras moving to cover stuff at one time.
So we are just mounting lights off the top of the set (or a stand behind the set, if the light is to large.).
