Stuart English
Red Team
Fan control
Fan control
This is the Operations Manual commentary about fan speed during record - four setting available. Quiet is the default.
Hot: This setting is most useful in ambient temperatures from 86°F/32°C to 104°F/40C. In this mode, the fan will run at its maximum speed. Other camera cooling precautions may be necessary, such as shading the camera from sunlight and application of a cold gel pack.
Standard: This setting is most useful in production studio conditions from 72°F/22°C to 86F/ 32C. In this mode, the fan will run at half its maximum speed.
Quiet: This setting is most useful in moderate temperature and humidity outdoor conditions up to 72°F/25°C. In this mode the fan will run at one quarter its maximum speed.
Silent: This setting is most useful in production studio conditions up to 72°F/25°C. In this mode, the fan will run at its minimum speed.
You can select any of these under any conditon of course. The camera will warn you if it is getting too hot. It will eventually tell you it will cease recording and shut down in 30 seconds if you totally ignore all the overtemperature warnings.
Fan control
