Johan Lindgren
All of B4 HD-ENG lenses I've been working with show these chromatic aberations, some more (wide angle zooms), some less - greenish and magenta, even stopped down.
Pretty annoying if you pay 20k or more for a lens. One big reason to avoid the B4 route on RED.
Hans
Edit: Never saw these things on 35mm. Was blind in these days probably. Does anyone know wether this is a "digital" problem? Zeiss DigiPrimes were fine, even shot wide open (2/3 needs to be shot wide open).
Those "chromatic abberations" you see in most B4 ENG lenses are due to the 3CCD design. I´m not sure exactly what causes this but the component colors are a little of from each other in the focal plane, its said to cause this magenta-green problem. Zeiss made their digi-lenses with this in mind so they are as a result of that free from this phenomen.
Check it out on their homepage
http://www.zeiss.com/C12567A8003B8B6F/EmbedTitelIntern/DigiPrime-Artikel-Gaengler2002/$File/spie2002.pdf
Roll down to
"4 the camera interface"
I dont know if for the same reason, they would be lesser suited for the RED camera or not.
Johlan
