- Banned
- #1
Admittedly, no one knows anything about the mini camera, but I'd like to think it's a less expensive (sub $10,000) 16mm type camera, since the market for this kind of camera is much larger than the market for super35, since most big studios rent and most consumers/film schools/smaller studios buy...and a 2k camera can intercut with 4k for close ups and handheld work: 16mm has been used extensively for close ups intercut both with digital (Apocalypto) and film (City of God) and it has a track record of working great.
In a similar discussion a while back, the issue of 16mm versus super16 sensors came up. The problem is that super16 requires special (expensive) lenses, but 16mm is 4X3--and most people want to shoot 1:1.85 or at least 16X9.
Then I read about "ultra16," a format that expands the negative slightly on both sides rather than considerably on one side but not on the other as super16 does, then chops off the top and bottom where the sprocket holes are. It's 97% the size super16, and problematic in the film world because most flatbed editors would scratch it, and few DI machines support the negative size, and there's no current solution for optical blow up...
However, the ultra16 sensor size and sensor placement (centered, not slightly off to one side as super16 is) allows for a full widescreen image that good quality standard 16mm optics can cover--and of course all super16 optics cover it, as well. This seems like a pretty simple solution in the digital world. So uhh...please?
http://marylandfilms.com/16mm-super16-ultra16-compared.html
