- Thread starter
- #41
Erik Widding
REDuser Sponsor
I'm hoping the iris can be rolled seperately from the focus possibly using a second control (Big Knob) so we can pull focus as we dolly thru a change in light.
That is the plan. Should the knobs have a switch that allows them to be dynamically changed in function? (i.e. four position: focus, iris, zoom, locked out)
The Asst. I showed it to last night thought that the "big knob" should have a hinge on the clamp so it can drop directly off the rod without needing to remove matte box, lens support etc. when moving to the Dummy side.
That is a good idea. We will make sure the screw and hinge part are captive. Is it okay for this to require an allen key? or is a thumbscrew preferred?
Will the Big Knob support remote hard wired operation for cranes etc? how far?
Does the Big Know allow us to use our standard Arri whips?
Probably fifty or a hundred feet off camera will be fine. How important is it to support a whip if the knob will work on a long cable and be easily removable from the rails?
Can you talk a little about how much the control stretches parts of the lens travel or moves the whole lens travel to a full circle of the control, About reversing the direction of the control travel re the lens, about repeating the marks when remounting on a lens previously marked, about your idea of ready made marked disks????
Things like reversal, range mapping and knob function, would all be settable from a computer, PDA or remote. The recognition of a lens would be native to the mount. It would be recognized when it is attached.
The exact functionality of what happens with premarked disks, and lens memories, etc, will be determined through interaction on this forum. I do not want to dismiss this, but rather suggest that the important decisions I need to nail down this week relate to anything that requires hard tooling. I encourage the raising of software issues, but will defer comments on many issues until next week.
