I Bloom
Like I don't know the answer to this question already,
No instead I'm looking for some help in communicating the advantages of RED clearly to non technical clients so for example can I say:
1. It shoots a 4K Bayer Pattern image. This means each frame of a movie shot with this camera is larger than 4000 x 2000 pixels in size, equivilent to an 8 megapixel digital still camera. Roughly 4 times the size of conventional High Definition Video.
2. The image is captured by a single sensor that is equal in size to a Super35mm film gate. It also mounts standard PL mount 35mm lenses. This means that all the depth of field characteristics of 35mm film, as well as the advantages of PL mount cinema style lenses are readily available.
3. The camera has over 11 stops of dynamic range. Twice that of conventional High Definition (????). Making it one of the first digital cameras that is suited for shooting exteriors in bright sunlight.
4. RED has the option to use an advanced type of compression called Wavelet transform. This technique is more effective at reducing the amount of data load during post production while maintaining a higher level of percieved visual quality than conventional digital video compression.
5. RED shoots a 12bits per channel in RGB color space. This makes it possible to do incredible color correction work in post that was previously only possible with scanned film.
I'm thinking about wording and about accuracy. About using phrases like 4 times the size of etc. I'm just interested to hear your thoughts.
IBloom
IBloom
