Erik Widding
REDuser Sponsor
Just a little teaser before we put out pricing and reservation forms on Thursday 5 July... (I am taking the holiday off.:bye2
We will be releasing Canon EF (August), Sigma SA (August), FourThirds (September) and Nikon F (October) lens mounts for the RED ONE camera. These lens mounts, through a mechanical adapter, can also be used on a RedRock M2, and other 35mm adapters.
Attached are pictures of the rail-mount follow focus knob and Canon EF lens mount prototypes. These were printed on a Dimension 3D printer using ABS plastic. The main housings of both will be made from aluminum, and the knob from injection molded polycarbonate. The bayonets will be made from stainless steel.
The follow-focus knob contains a 4096 count magnetic encoder; is selectable between single turn with hard stops, and multi-turn; has a friction adjustment; and has snap-off markable rings (white part). The lens mount has a built in bluetooth antenna. Each module has two LEMO 0B connectors for daisy-chaining power and RS232 from the camera to these (and yet to be announced) modules.
In addition to the open Birger protocol, the lens mount also speaks Fuji and Cooke-like lens protocols so it can be used with existing lens control, data-logging and data-display equipment. The protocol used on each of the three ports (bluetooth, 2 x RS232) is configurable on a port by port basis.
Changing lens mounts requires disconnecting one (or two) LEMO 0B connectors from the bottom of the mount, and removing and replacing the four screws (visible from the front of the mount in the images) with an allen key.
More on Thursday...:whistling:
