- Banned
- #1
conrad gaunt
Banned
- May 31, 2007
Encoding/Decoding:
I was just wondering, would it be possible to upgrade the encoding/decoding data rates with a future software upgrade or is Red encoding/decoding hard-wired to a circuit, or limited by resolution and processor speeds etc. I don`t know if this is of interest or has been discussed before, but I could imagine I`d really enjoy being able to lower or raise data rate/quality settings as I need, especially if drive speeds/size keep increasing.
Future of `Film` archiving:
What is the future of digital film archiving? Traditional film ages over the decades, but digital lasts forever, right? Or does it? Well it probably does if you use a fail-safe raid system (so you can detect errors, as well as fix them) and then transfer it to a new raid every five years or so. Thats about twenty new raid systems every hundred years (if your lucky). Unlike film, that degrades slowly, digital copies can disappear instantly if your not carefull, or just unlucky. Then there is Power surges, Fire, Lightning, Electro Magnetic Pulses..
Files can also develop errors quietly too, unless you use a safe RAID, or keep two copies on different disks, it can be hard to fix and harder to spot errors, especially if a clip isn`t being played often (ie archived). TIP, If you do this two disk thing, i recommend you zip each copy up (yes it takes ages), not necessarily for compression (but that can be useful too), but error-detection - build with recovery records and verification data. By unzipping you can confirm its an error-free copy and replace a known damaged copy. No point replacing damaged with damaged. I use this to back up important WAV files at present. I don`t think a good solution to this archiving problem exists at present, short of engraving your work onto slabs of stone in pure binary using a very small hammer, or, and this will seem silly, transfering a copy onto film, which isn`t an exact copy anyway (or a binary copy on micro-feish perhaps?), long term survival of digital media might be tricky. I`m thinking more about historical footage than blockbuster movies. My hope is that future disk systems cost the same as they do now, but become thousands of times bigger, so I only have to replace one at any given time.
I won`t mention the problems of proprietory file formats and their future compatibility, or suitability for archiving, but it may be necessary to migrate digital media between different formats through the years, which will be interesting.
ps, I`m personally very excited at the thought of using DWT (wavelet) as apposed to DCT (blocky 8x8 mpeg style) encoding. I`ve been getting sick of red and blue being treated as second and third class colours too, viva 4:4:4
pps, If you want a lossless encoder capable of encoding YUV or RGB colour, search for HUFFYUV codec using google.
