Andrew M.
I did do a lot of reading today.
Looks like we have to go FL 8 to 12 for 2.35 screen ratio and 14 – 16 for 16:9
This is as far as open views, no inside the small limited spaces.
If you do want nice panoramic views where wide screen is in it’s best.
Under the water wider you go less water you have, except the caves long shots where crystal clear water is not the problem as far as visibility is concern.
Looks like good primes 8 to 10 FL are $100 to $300 a day so I rent before I buy and test it.
I use RGB to make sure that we are talking 3 pixels here since 8MP Canon someone may mix up with actual 8M pixels on the screen.
