Andrew M.
As Stuart said, two HD-SDI ports will have monitoring outputs on top of EVF and LCD port.
As to the EVF and LCD why not to pick HDMI it supports 1080p60 RGB and all other 720p and 30 24 and other frame format.
It is very popular not expensive and very easy to get monitor for it.
If you have any high end remote monitor than most likely it will have HD-SDI interface on it.
Stuart, it is a good idea to have an option for 1080p60 just in case. Though the standard EVF and LCD could be 720p to start with.
Andrew
Andrew
