Hi!
Now when we have this options to make timelapse with RED there also should be option to use long exposure i.e. 1-10 seconds or even more. That would make it possible to make so much different timelapses than with 1/2 second exposure time.
I do think it wouldn't be ahrd to add that when the timelapse options is already made there. Now you only need to work with some more time.
I tested it with Varispeed mode with 1fps / 360° shutter and also with Timelapse mode with frame per 1 and 2 second / 1/2sec exposure time. When you need to get some motionblur your timelapse only the Varispeed will now give the nearest result with the 360° shutter. I think if there would be long exposure times in timelapse option it would made the RED more usable and better camera.
Maybe in next build? 17 or 18??? =)
