- Moderator
- #1
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
35mm f2 AF Nikkor
History:
The 35mm AF Nikkor was redesigned in 1988 for the auto focus version. It's one of those lenses that is truly superior to it's AI/AIS manual focus version. It even rivals the 35mm f1.4 AI/AIS which is legendary. It was updated to the (AFD) version in the 90s but optically is identical.
Sharpness (edge enhancement) was set to 10 in Adobe ACR.
Performance:
A testiment to this optic is that it only barely gets better as you stop it down.
Use the Zoomify links for 10%-100% viewing
http://www.reduser.net/evin/35mmf2/Zoomify/35mmWf2.html
http://www.reduser.net/evin/35mmf2/Zoomify/35mmMf2.html
At f2 the contrast is lower and a small amount of fringing can be detected but it's resolving loads of detail. A much better wide open performance than the 50mm f1.4.
http://www.reduser.net/evin/35mmf2/Zoomify/35mmWf4.html
http://www.reduser.net/evin/35mmf2/Zoomify/35mmMf4.html
By F4 there is nothing really to complain about. The small issues that might have been visable at 100% at F2 are now gone.
http://www.reduser.net/evin/35mmf2/Zoomify/35mmWf11.html
http://www.reduser.net/evin/35mmf2/Zoomify/35mmMf11.html
F11 shows the most detail and micro contrast (but not by much) and offers the best choice for deep focus shots. All CA, fringing and other issues are nonexistant here.
http://www.reduser.net/evin/35mmf2/bokehtest.gif
Bokeh is very plesant, not as smooth as the 50mm 1.4 or the 35mm f1.4 AI Nikkor but nice none the less.
http://www.reduser.net/evin/35mmf2/breathtest.gif
This lens does exhibit some breathing, especially in close to medium transitions. At medium to far distances it is much less visable.
Build and adaptability to cinema shooting:
The standard AF Nikkors do not have the bulletproof build of their manual focus or professional AFS brethren. None the less thay are perfectly able to withstand the rigors of professional use. The focus is smooth although a larger focus draw would be nice. The aperture ring is plastic but sturdy.
Application:
This is very high performing optic in the normal range (58mm Equiv. in 35mm still) of the Red's use. If your budget keeps you from owning a 35mm f1.4 AI this is a much better choice than the f2 manual focus version. It will focus very close as well (9 inches!) so shooting wider inserts is no problem. However it is debateable weather this lens add's anything over the 17-35mm f2.8 AFS Nikkor other than size and one F stop.
Price/Value:
With a new price of $330 and a used price in the $200-$300 range it's obvious this lens holds value for a reason. Either way try to find one in good condition. If you're putting together an inexpensive prime set it's ideal and worth every penny.
I suggest http://www.keh.com
Uncompressed Tiffs (27MB each, please be patient)
http://www.reduser.net/evin/35mmf2/35mmWf2.tif
http://www.reduser.net/evin/35mmf2/35mmMf2.tif
http://www.reduser.net/evin/35mmf2/35mmWf4.tif
http://www.reduser.net/evin/35mmf2/35mmMf4.tif
http://www.reduser.net/evin/35mmf2/35mmWf11.tif
http://www.reduser.net/evin/35mmf2/35mmMf11.tif
History:
Performance:
Application:
Price/Value:
