Patrick Tresch
Hey Isaac, thanks for the test! You made some very thorough notes of the camera's temperature and fan speed.
But I was wondering if you made any notes for the actual decible levels you were recording? I'd also be interested in a test where the mic wasn't pointed directly at the camera, but in a setup where it would most likely matter. Like the mic was 2 ft higher than the camera and pointed down, as if in a sit down interview.
I wonder why you would like such a test as we know that the Epic makes fan noise and the aim is to test the different solutions out there? It would make sense if like I did once you would liked to compare the.noise of the Epic with the Alexa, the F65 or the delta Penelope.
But your test holds to many variable to make it usefull. Can we make it in a scientific ISO configuration?
Pat
