[FS: GEAR] DV4II w/ 75mm 2-stage CF tripod and floor spreader
Adam Spafford
Banned
This is a dv4 with Tripod and floor spreader.
I had two for sale, but one was sold. The other one I have has an issue with it, so price is reduced.
The screw the locks the pan movement into place is missing, and even if the screw was there I dont think it will lock into place while panning. Still if you adjust this to the lowest pan, it moves very slowly and holds itself into place. This still works, and has been used on set in it's current condition. Could be fixed, or used as is.
$400
perfect balance across the horizontal plane. The settings cannot be lost once it is adjusted. Also included is a single pan bar DV 75.
loading Wight ?
