Unable to activate HDRx on Scarlet
Nicolò Rebughini
Italy
How do you turn HDRx on on the Scarlet-X? I tried all this morning but seemingly I can't find a way to activate the HDR mode, once I select HDR from the menu on the touchscreen, the options "HDRx" and "OFF" are greyed out and I can't select them.
I lowered the resolution to 3K and even to 2K but the options are still greyed out. I am on stable firmware V4.
What do you think it could be the reason?
And what Redmag media are you using?
I've only run into that when frame processing is enabled.
Double check all the "features" you might have active.
Otherwise do a "Restore System" to bring the camera back to factory defaults, and see if you can then activate HDRx
I have the 64 GB Redmags. I also tried to lower the compression ratio, down to 10:1, but to no avail.
I double checked that all "features" like frame processing or similar options weren't enabled but that didn't work. Instead doing a factory reset worked flawlessly! Thank you guys.
Have the Sensor Sync Mode set to Genlock is a common reason people run into this. Of course, resetting to factory defaults will undo any setting that was causing the lock-out to begin with.
