Pink sky
Seems like you clipped the highlights, meaning some portions of the sky was overexposed causing a pinkish cast to appear on the footage. You can grade it to match your scene, but won't be able to recover it. You can always post a screen shot or r3d for others to examine.
When you clip your footage, not all the channels clip which cause it to go pink. Use the DRX function in essentially balance the highlights to clip to white. You can do this manually to with the curves but DRX is too easy.
