Upgrade from 10.5.8. . . will Premiere Pro CS5.5 still work?
Stephen Pruitt
www.thetreemotionpicture.com
Hi all. . .
. . . big time concerns here.
I am currently using CS5.5 and OS 10.5.8. It works perfectly.
Now, to use a new piece of software (iZotope RX-3), I need to upgrade to OS 10.6 or later.
If I upgrade for the iZotope, will I STILL be able to use my CS5.5 without a hitch?
I'm VERY wary of any changes this deep into our film.
Specifics:
2008 Mac Pro: 2x 3.2 Ghz Quad-Core Intel Xeon
Nvidia GeForce 8800GT
Am I likely to encounter any problems?
If I do upgrade to 10.6, and if I have any problems, can I go back to 10.5.8 or not?
Thanks much.
Stephen
No one???
Alas. . .
. . . I just may be toast.
Stephen
Come on Adobe, chime in here! Will I encounter any problems moving from 10.5.8 to 10.6.8 using my CS5.5?
Help a guy out here.
Stephen
You will not have any problems moving to 10.6 or even 10.7 I've had both of those OS versions running with 5.5. I can't speak to 10.8, as I've not had to revive 5.5 for anything since installing it.
And yes, you can go backward. But you may not be able to do a time machine-style transfer of your user data, etc. I don't think the migration assistant goes backward. So be sure you make and keep a clone of your OS drive before you start. That way, going back to where you started is always possible.
Thanks, Mr. Fuller, I really appreciate it.
Stephen
