Blair S. Paulsen
- Dec 28, 2006
- San Diego, CA
- www.alacritymedia.com
I am not an engineer, I don't even play one on TV, but I'd sure love the rock star engineers at RED to consider the feasibility of the following:
RocketDeck:
Put a RedRocket-X and a RedStation mag reader in a stand alone chassis with multiple I/O options. Can be connected to computers via Thunderbolt 2, USB 3, etc and used as an external RedRocket-X appliance with a mag reader on the same fast bus, as well as direct connection to monitoring over SDI, HDMI, etc.
Include a mid-level CPU, RAM, 256GB SSD and an OS so if desired it could stand alone. Design it to be controlled from a laptop, tablet, phone, USB, Bluetooth, etc. The Rocket-X is doing the heavy lifting as well as providing monitor output(s) for GUI and full quality clean image (laptop, tablet or phone could display the GUI as well) so the "host" would not need expensive high end chips.
Now you have a roughly $10,000 (rack mountable please) black box that can be used to play out r3ds at your resolution of choice up to 4K in real time. It could use RedCinePro-X or something similar as the control environment so you can tweak the image to taste for the live outputs. Among other things, this would allow you to push out a graded RGB image at UHD or 4K over 4x SDI or other appropriate I/O for ingest/recording/etc in real time.
RocketLink:
Now here's the kicker. What if you made plugs that fit into an Epic SSD module, using the existing pins/contacts, and fed that out over fiber (tactical please) to a matching plug on the other end that fit into the mag reader in the RocketDeck. The RAW bitstream would then be decoded by the Rocket-X, "shaded" by the virtual CCU provided by the look tools in RedCinePro-X (or perhaps a modified version of same) and sent out to the switcher over SDI or HDMI for live hardlined production applications.
This topology allows the heavy decoding effort to happen away from the camera so no expensive, heavy, power hungry, heat generating module has to be added. In addition, it allows the metrics of the decode and playback to be managed at the technical/switching station in the truck/control room where "shaders" have traditionally been situated. Yes, I realize actual iris control would probably not be supported, but the operator could set it manually to something appropriate to the situation, and with 16 stops of DR the shader should be able to ride the levels and match the cameras nicely.
There are probably gotchas I haven't thought of, but I like the fact that it shouldn't require any re-engineering of the camera itself. It might even support iso recording by adding a rear SSD module in addition to the side SSD - not sure if the internal signal routing would allow that, but it seems likely. IAC, always looking for ways to use my favorite camera in a wider range of applications.
Cheers - #19
RocketDeck:
RocketLink:
Cheers - #19
