Desisti 2.5k HMI - Shuts Off
Caleb Vetter
40
Kansas City, MO
I have a Desisti 2.5k HMI with electronic ballast and after about 10-15 minutes it throws the breaker on the house. It's a 30 amp circuit so there should be plenty of room, plus I know I've used it 3 times before for well over an hour in the very same conditions.
Any idea what's going on?
what specific head do you have and ballast? I have the piccaro 2.5k fresnel and a light maker 2.5/4k ballast. considering that you have run it before successfully perhaps a short or voltage leak that is causing it too draw too many amps...? best to have gilbert at galaxy lighting repair look at it. my ballast runs 40A at 120v or 20A at 240. is voltage dropping from the source (ie your house...?)
It says Rembrandt model 2520 "Piccolo".
I'll have to check for a voltage drop when I can get my hands on a meter.
Is Galaxy Lighting pretty quick?
