Mike Halper
- Jun 4, 2009
- Age
- 49
This weekend I successfully built my first Hackintosh. Everything is working great and it's stable with a 4.5 GHz overclock and 2400 MHz RAM. The only problem I'm having is getting my Atto H680 to work. It seems that when I have my Red Rocket installed the H680 won't work. Take out the Rocket and the H680 works. My Decklink (normally in a Thunderbolt enclosure) card works in the same slot while the Red Rocket is installed. The H680 also won't work via Thunderbolt if the Rocket and Decklink card are installed. Remove the Rocket and it works via Thunderbolt. The H680 doesn't show up anywhere, as if it's not even installed.
Is anyone aware of a conflict with certain cards with the Rocket and how to fix it?
I'm using a Gigabyte Z77X-UP5 TH motherboard and i7 3770K. Graphics card is the EVGA GTX Titan Superclocked. Gigabyte says there's no settings to change for the PCIE slots since they're controlled by the CPU. I've had zero issues using the Rocket and H680 in Thunderbolt enclosures with my MacBook Pro.
