Abnormal amount of stuck pixels (colored grain), within tolerance?
Let me guess... Timelapse? If you are shooting with dramatically different exposure times (ie. long exposure timelapse when you black shaded for 1/48th) than what your black shading is, you'll see things like this. Do a new black shading with the exposure time (and ideally camera temperature) that you plan to use.
Yup, Sam is 100% correct. There is nothing wrong with your camera, you just need to black-shade for any dramatic changes in exposure time and/or temperature shift...
This is clearly indicated in the UI. If the E/T is lit green - you are within the range of your black-shade. As you go further away from these limits the green will turn yellow and eventually red. This means you will have severe noise / RGB noise in the image...
:sifone: Peter
