Epic and Scarlet BUILD 4 V4.0.12 FIRMWARE
Jarred Land
Fire Chief
Staff member
Enjoy... Most notable change is that this build supports the new top and bottom fans as well as cleans up some outstanding bugs.
SCARLET: https://www.red.com/downloads/4f56854e6261f95a570006ca
EPIC: https://www.red.com/downloads/4f56854e6261f95a5700069b
[h=4]SIGNIFICANT CHANGES SINCE PREVIOUS BUILD V4.0.10:[/h]
  • Added top and bottom fan support
  • Added pre-settable recording options
  • Fix unlock screen with notification
  • Fix ramp list to use entire FPS list
  • Fix playback failure
  • Fix audio output for HD-SDI 720P60
  • Fix error on HDRx record stop
  • Fix double tap capability for 9" touch screens
  • Fix split-screen when toggling magnify
  • Fix relative shutter calculation on frame-rate updates
this is the release version ?
(I see it not stated otherwise but usually there also comes a newer beta or first beta then release - so I just ask)
Excellent timing as I am opening my new Epic-X.
  • Thread starter
  • Admin
  • #9
Welcome to the family Jay and Jarek :)
yes this is a release build.
Great update! Can't wait to put down the money for the fan upgrade now:-D
Noticed a bug in previous version. Haven't tried this version. Running the +1 module for secondary screen, after the camera went to power save standyby the touch screen on the brain port stopped working. Had to go into settings with he side handle and change the Hz of the brain lcd for it to come back.
I can confirm that the above bug is still there (on EPIC-X). I have the soft keys assigned to various shooting presets and when the camera comes back after power save (with assigned button) the touch ability on the touch screen no longer works. It's solvable with a restart or Hz change in the display menu. as far as I can tell this only happens with the +1 module attached.
Other then that great release, love the adaptive fan mode / temp control.
you create any New Firmware for REDONE-MX?
Thanks for the feedback. We'll look into the touchscreen behavior with +1 and power save.
Thank you for the update. It is great to have double-tap working on my 9" monitor. It worked on zombies, now on Epic...
