Can you mount an LCD screen (9") on top of a RED sliding handle?
Craig Knowles
Active member
Cleveland, Ohio
On top of my Epic, I have mounted a swat rail and a sliding handle:
http://www.red.com/store/products/sliding-top-handle
On top of the sliding handle is a single 1/4-20 hole.
Is this single hole strong enough by itself to mount a 9" RED monitor?
I would say no, so my next question becomes "Is there anything I can mount to the 1/4-20 hold that I can then mount my 9" monitor into?
It seems like there must be something out there given all the mounting points on the handle itself, but I haven't been able to find anything.
if you don't use the rosette on the front you can remove it and then mount the screen to the holes just below that.
or mount the handle facing out toward the lens and put a swat rail on the back of the camera and use the swat rail clamp to mount the screen to that
How do you remove the rosette? Are these holes you talking about underneath the rosette plate itself?
