Filming just above the water line
Willy Faes
Antwerp, Belgium
Hi Redusers,
I'm going to shoot a short film in Italy next week.
One of the shots is as close as possible to the water.
I was thinking of putting the camera in a aquarium (small fish tank) but my DOP thinks the reflections are going to ruin the shots.
Anyone had any experience with this?
Willy Faes
Producer/Director
Aquarium works fine. Just make sure the lens is against the glass so there are nearly no reflections possible. And its good to have something like rain-x so that water drops on the outside dont stick to the glass and stay in the shot.
bring some linear and circular polarizing filters, and make sure your matte box can spin them ... that way in most cases you can remove anything you don't like.
This. This is exactly what I was going to suggest. A polarizing filter, properly positioned (as in, properly rotated), will remove the reflections.
Try to get a coated glass and replace it with the glass in the aquarium, even though I wouldn't touch an aquarium in the first place, waves, etc.: Check you insurance.
I would be careful with a Polarization filter, it might take partly the reflections from the water as well, certainly no nice, as water is expected to be reflective.
An under water housing is the way to go, but as well the most expensive way. But if you get your camera really wet, and no other camera on set, that would be cheaper then.
Good Luck.
Halfway between the expense of a UW housing (which is definitely the way to go) and an aquarium is to rig a surface coated mirror at a 45 degree angle on a float, then under sling the camera in a support system above / lens towards the mirror.
Flip the image in post.
I have shoot for a boat company several times and have used the aquarium trick several times. With a little care it works great.
