Charles Papert
- Jan 1, 2007
- Los Angeles
- www.charlespapert.com
Some good work there Dave, although you are throwing away some valuable inertia by positioning the rear battery vertically rather than horizontally. Another potential issue is if you are boomed up and have to pan the sled through the position where the battery could hit the arm, or if using a long armpost. Also I'd recommend losing the ball joint mount for the monitor and going with a mount like this that will allow you to adjust tilt on the monitor without affecting other axes while wearing the rig, or even better making a yoke for your monitor so that the balance doesn't shift when tilting.
