Todd Kopriva
- Sep 2, 2010
> However, I barely get smooth playback on my own computer, let alone over a network. I really am wondering what kind of minimum system specs you need to really to get the same results as what was in the demo video.
The idea of this system is to have very powerful machines on the server side that can do the heavy rendering so that all that your client computer needs to do is display the results. Over the connection that we had on the tradeshow floor at IBC to the server in another country, we were seeing no compression artifacts. You'll get smooth playback over even a network connection with less bandwidth, since the playback stream is dynamically compressed depending on the available bandwidth. You always get full, uncompressed frames on pause, no matter what the connection speed.
We've been demonstrating the client software running on a MacBook Air to make the point that this system removes nearly all of the burden from the client machine.
