Scarlet Build 4 menus missing on HDMI monitor
Ryan Michael
Northern Ireland
Hi Guys, just updated our Scarlet 'Prudence' to Build 4 and now on our 3rd party HDMI monitor the menus are missing. We had this issue before on older builds but the force preset file I usually use seems to be ineffective on build 4. Would anybody have a force file available to fix this? Or do I have to wait until RED provide it?
Thats it, thank you Jonas! For anybody else with this problem put the 720p hdmi preset file into a folder called 'force_preset' on your SSD.
If you add a preset, how do you remove it if by chance you want to use an HDMI or SDI recorder for backup? "remove_preset"?
EDIT: Never mind...found out how to delete through the preset folder!
Note that deleting a preset does not undo the effects of applying the preset. The force preset files in the DSMC Resources files simply set the HDMI/HDSDI to MENUS and sets all the other monitors to CLEAN (allowing you to use the camera without a touch LCD or REDmote).
