Michele Lombardo
- Feb 14, 2010
- Age
- 49
- milan, Italy
- www.m1media.it
Hi everybody,
after some weeks spent in testing and understanding the Sekonic 758Cine, these are my results:
- I used the Sekonic Target II
- I used the grey side to measure the white balance and checking to have the same light on all the surface (I used two Kino)
- RED MX false color helped me to easily set up the Kinos, achieving a total "green" on all the target
- I checked with the 758 the lighting on all surface
- I turned the target
- RED MX was set: ISO 500, 29.97fps, 180° shutter, T5.6
- 758 was set: ISO 500, 30fps (cine mode), 180°
- Sekonic DTS software starts asking the two measurements (incident and reflective): ISO 500, shutter 1/60th and the apertures measured were 5.6/0 and 5.6/0 (I had the same)
- Then I shot 3 mini video: a "flat" one (0EV), one at T2.0 (+3.0EV) and one at T16 (-3.0EV)
- I export three TIFF frames from RedCine-X Pro
- I converted them in JPG using Photoshop (discarding color profiles)
- I put these three jpgs in the DTS software
- NO ERRORS AFTER PROCESSING DATA!!!
- I upload the profile to the 758
After this process I wanted to double check the 758 was correctly calibrated: framing the Target II, I changed Tstop, ISO, or fps... Sekonic 758Cine and RED MX false color were ALWAYS equal (measuring the 18% grey).
I attach my graph!
I also check the noise area and the clipping area: noise stars BELOW 2.0 FL and clipping area starts BEYOND 53 FL.
What do u think?
Michele
I attach my graph!
What do u think?
Michele
