Nick Morrison
- Nov 9, 2011
- Brooklyn
- www.smallgiant.tv
Avid still not resolution independent !
What do you mean by this exactly? You can mix frame rates in sequence. But yes, you can't mix 720p or 1080. It asks you to pick your resolution and then converts everything to that master deliverable.
I used to work at a major cable network that used resolution independent FCP. They would mix 1080p, 720, 1080i, SD, and web formats...all in one sequence. For 2-3 min network sizzles. As the weeks progressed, the project got slower and slower, renders piled up, as the edit got more and more complicated. By the end of the sizzle, a month in, the machine could barely playdown the sequence. And when they had to finally lay to tape? The project had to render everything one last time...and took almost an entire day session todo so.
At the network I currently work, they tore out all the FCP rooms out because the resolution independence caused too many renders before layoff to tape. FCP is only used for web work right now, where it legitimately is very fast as long as all the files are one resolution and all the QTS are pro res.
