William Robinette
Never had a problem with mine either. Bullet proof.
Two words.
"prep day"
Part of your rental and budget needs to be devoted to prep, the day before, in the rental house, so that you have everything tested and working.
To clarify, it's the audio that disabled the monitor. When we enabled the audio in the menu, the HDMI port stopped working (despite showing enabled in the menu). When we disabled the audio, the HDMI started working again. That's when we switched to the SDI port, which did not seem to be affected by the audio setting.
With all the anti-drone sentiment these days, it's good to know "Caliente" can take a "direct hit" :thumbup: Just to be safe though, maybe a kevlar jacket is in order!
Totally disagree. It is absolutely positively 100% the rental house's job to test, clean, and repair the camera every time it goes out and comes back. Expecting the customer to pay for the privilege of doing it themselves is ridiculous.
Before I write the Scarlet off completely I wanted to get your thoughts.
It seems that whenever we have the Scarlet on set we spend the entire time debugging and rebooting. The client, crew and talent are all standing around while the camera department is trying to figure out what's going on with the camera.
For example, on set yesterday the camera would shut down by itself for no reason... batteries or wall power made no difference. Then it would kill the monitor signal. We figured out that our camera would not output HDMI and input audio at the same time. In other words, if we wanted to monitor the video through HDMI we had to disable the audio input. HD-SDI still worked.
Last month we had similar issues including error messages, dropped audio, unexpected shut downs. We rent from a rental house that has a fleet of 5 Scarlets, so I'm pretty sure we're not getting the same one each time.
The Epic has some quirks, too, but nowhere this bad. What are your thoughts? Typical or are we having bad luck?
Thanks for the feedback, guys. Very helpful. On set I kept thinking, "This is why the camera is so dirt cheap to rent." Among other not-so-nice things.
The rental house we use is not know for keeping their gear in tip-top shape, so that may have been a factor. I always get a DIT and we usually do have to upgrade the firmware ourselves during prep day. The firmware on this one was one version behind, which we didn't think was a big deal.
The DIT did a factory reset on set, after which the reboot issue improved somewhat.
You are entitled to your opinion, but I've never seen a production totally trust a rental house or vice versa. I don't know many pros who'd agree with you unless there is a prior relationship and even then it's sketchy.
The OP even states he had these problems with this rental house before.
A prep day helps both sides.
1. Troubleshoot
2. Jointly establish exactly the condition of each piece being rented.
3. Build and test the camera as it will be on the day
4. Set up menus framerates, black shading, etc.
You want to leave all of this to what? The morning of the shoot?
You'd be doing yourself and your client a disservice.
Even at a car rental there is a walk through and that's just turning a key putting it in drive and going on your way, it's hardly like prepping for work on a professional film set.
David
A couple DITs told me that having to power cycle the camera a time or two on set to fix some quirks is pretty normal.
As for HDMI, everyone is pretty much in agreement that we shouldn't be using HDMI on set, anyway. Case in point the SDI on the Scarlet worked flawlessly.
