robert sala
- Feb 25, 2011
With two Sonnets and 8x2TB disks in each. When Mercury Viper SSD comes out we plan to reach 4000-5000 MB/sec (30-40 Gbit /sec) from one set of 8 SSD raided.
ahem...It's not a RED machine-yet, serves Resolve/FCPX/arriraw/4k (3xGTX680 in Cubix). But RED is definitely in the plans.
Sure we have CS6. What would you like us to test with this double Sonnet RAID?
We'll try that at the weekend at the latest.
To make sure what you are looking for:
--to test Red 5k decompression and debayer by Macpro 12-core with 1300mbyte/sec storage using CS6 and NO redrocket
We haven't done red yet (good to start finally) and I have a question about the significance of the fast storage in that case.
Red 5k will be compressed and the needed bandwidth for storage adequatly smaller:100-300 mbyte/sec .
(The full 5k DPX might indeed stretch the storage speed.)
CS6 will not use the full 3x gtx680 power in that case
What are you after in this test?
Very tentative results. It's the first time we played with R3D on our machine.
R3D 5k (5120x2700). www.footage-online.de/free/red-footage.html
The test file is small (7 seconds, 600MB) so most likely it gets cached in RAM.
In fact the speed of storage probably does not matter here as we got the same results for all three kinds tested.
MacPro 12-core/64GB RAM/Quadro fx5600/ML 10.8.2,
(3 kinds of storage were tested :Sonnet2x 1300Mbyte/sec read RAID5 ,
3xSSD internal 600Mbyte/sec read, xsan/fc 420 Mbyte/sec read)
RESOLVE: full res--7fps
1/2 res--22 fps
1/4 res--23fps
PREMIERE: ful res--unwatchable
1/2 almost good
1/4 perfect
Then we attached CUBIX with 3x gtx680
RESOLVE: ful res 21-22 fps even when adding nodes of blur
1/2 res 22-23fps
PREMIERE: same performance as without Cubix
Next week we'll try longer/bigger clip to saturate RAM.
Also we'll try to put gtx680 as the main GPU to see if Premiere improves with it.
There are some glitches to work out too (with Cubix, cards etc)
The clip was still only 600Mb and probably all got cached in RAM, so storage speed played no role in the playback quality.
Robert,
You are the man! If we ever meet, the drinks are on me. Thank you for taking the time to detail the tests.
So conclusions?
Without a RR, FULL REZ, is not happening?
