nima
Hello,
I am experiencing another problem with CS6 and R3D media.
I am trying to move a PPCS6 project to an external hard drive in order to send it out for DI work.
From Project Manager I select "create new trimmed project" with 24 frames handles.
Once all the files are processed the resulting new project is huge and none of the clips have been trimmed.
I tried to create a test sequence, with only 2 minutes of editing to see if the problem could have been solved with a fresh new sequence.
Unfortunatelly I get the same rusults.
CS6 is giving me several headackes with r3d media. I have been having several Unkown Errors while rendering or exporting different projects.
Now I realize that CS6 cannot properly archive or copy trimmed projects.
This is one of Andrew Davis's links that explains the archival process. Unfortunatelly it won't work woth r3d media:
http://library.creativecow.net/devis_andrew/Archiving-Projects/1
Pease let me know If you ever ecountered a solution to this problem.
On the other hand my real question is:
how do you guys archive your PP projects once you are done editing all those beautiful images that an Epic/RED camera shoots?
If of any help, here is my setup:
MacPro 12cores
64GB ram
RedRocket
nVidia Quadro
Media is stored in an Internal raid
Project Manager is set to export the trimmed project on a regula G-Raid drive with sufficient space and speed
Thanks!
MacPro 12cores
64GB ram
RedRocket
nVidia Quadro
Thanks!
