Allee Chance
I'm using the Bartech FF for the first time with Red primes and I'm encountering two issues.
There is too much gear noise.Not so much a problem on a slow turn but on a rack focus it is too loud. It requires considerable effort to turn the focus barrel. Perhaps this causes extra pressure on the gears raising the noise level. Any suggestions? Can the lenses be changed to turn more easily?
Second, and possibly related to the effort turning the barrel,and when the motor resets to mid-range after set up the gears are stripping because the motor is turning faster than the barrel can keep up. Eventually the motor gear moves away from the barrel and the motor spins and thereby losing calibration with the barrel. I have tried different gears and I have the optimal one on. Jim Bartell suggested stabilizing the rods with perhaps a cable tie so they don't bend away from the barrel. Any suggestions?
Thanks!
Allee
Thanks!
Allee
