Uli Plank
- Apr 18, 2007
- Age
- 73
- Braunschweig, Germany
- www.hbk-bs.de
I had a bit of time today and thought I'd put a cine Distagon, the Arri/Zeiss 40mm 2.1 T, against a few of my stills lenses to check them for exposure.
The results are interesting: while I always thought that all marked F-stops would be slower than the marked T-stops, this is wrong!
All lenses were slower in T-stops when wide open, but starting from the first stop closed down, the values were constantly identical to the F-stops (within an error margin well below one third stop).
One example: the Minolta Rokkor 58mm f1.2 (aka Bokeh-Monster) has a T-stop of 1.4 (true speed) wide open. At f2.0 the value is identical to the lens with the marks in T-stops. This was the same on all the lenses I tested, a few Minoltas, Zeiss Contax and one Voigtländer (compared on a GH2, not RED). OK, not a fully scientific test, but good enough for me. For most practical purposes I can consider my lenses closed down as marked like T-stops, only the WO values are exaggerated.
Voigtländer 25mm @ f0.95 is a T 1.1.5, Minolta Zoom 35-70mm @ f3.5 is a T 3.8, both Rokkor PG and Contax Zeiss @ f1.4 are T 1.6, even the Rokkor 28mm @2.0 is a T 2.1.
Thought some might find this useful…
