Green Outline On Elements of Shot
Andy Maser
Portland, OR
Has anyone else ever noticed green outlines on elements of shots from Scarlet? This is the second time it's come up for me--anyone know why it might be happening?
My first thought was that it could be because the sensor isn't warmed up yet. Thoughts?
I've seen something similar when the sharpness slider in RCX is pushed up to 3, but usually not that bad.
That looks like chromatic aberration from your lens. Do you get clean images when the lens is wide open and pointed at a bright background in other situations?
I would say lens chromatic aberration.... you have a green flair on one side and a magenta flair on the opposite...
If CA is visible a this size the lens has a serious problem…
This is not CA - CA gets worse towards the corners and notice how the left-most highway support column has none. Also CA does not exhibits itself in such a large patches, but rather thin hallos around the lines of high contrast. My money is still on proper black-shading...
