Going back to 24fps, after frame ramping!
Alan Thornton
The O.C.
I just did a test, with my Epic-X, using the frame ramp function.
The camera is set to record @ 24fps and when I trigger the frame ramping,
it goes up to 96fps, 4kHD setting.
The problem is when I stop recording, the frame ramping stays at 96fps.
Shouldn't it default back to 24fps, when the recording stops or do I have to go back to the menu and reset the desired frame rate, in my case, 24fps?
Any help is appreciated.
Yes it should go back. Can you open a support ticket and send in a log file?
We've been able to reproduce the error. It occurs if you trigger the action "Record: Start Speed Ramp" more than once during a record. Hopefully we'll get this fixed in the next beta release. Thanks for reporting the issue.
