SmallHD monitor
The TVLogic 5.6" uses the exact same LG LCD as the DP6, only difference is the software, architecture and the name.
Should I buy the hd-sdi version or will the hdmi just be fine?
HDMI is a horrible connection for anything that moves around, like cameras. HD SDI, on the other hand, is a professional connection and can be used on numerous other pro cameras.
Once you use HD SDI you'll never go back. :)
