Fernando Tufiño
I´ve been using my Scarlet for a while and lately i´ve been trying to shoot with the "Raw Check" always on and just exposing that image right, so I could practice color grading and understand what I can do with the image a little bit more.
My question is, basically, is this the most efficient way to work with Red?
Also, after doing some tests with a lightmeter, a 18% grey card and using the "video" function for correct exposure (properly lighten with tungsten lights in a film set, 4k, 25fps, 1/50, 3200K, ISO 800) I found that the true native ISO of my Scarlet is 320, but then I turn the Raw Check mode on, and I found a significant drop. Doing the same test I found that the native ISO with Raw Check mode on is 160!!!
160 ISO... does this means what I think? Can someone please verify this?
I performed this tests side by side with a Red One and I got the same results, slightly better dynamic range with the Scarlet.
I am a little concerned of how much gain I´m actually giving to the image when not using "Raw Check" mode.
Please respond if you have helpful information. Thanks in advance.
