Cinemods OCT-19 Mount
Adam Johnson
St. Louis, MO
Does anyone know if the Cinemods OCT-19 mount works with LOMO lenses with OCT-19 Mounts that have the "metal tab" on the mount in the picture?
Thanks a million!
Adam
yes, works perfectly. I'm quite happy with it. I have yet to find an oct19(OST19) lens that is too deep or large to work with the mount. However when collimating my anamorphics with it my lens tech noticed that it was very, very, slightly out horizontally which would obviously make a difference to anamorphics but fine with aspherical lenses.
Thanks Ev!!!!!!! Do you have any samples of your work shot with your LOMOs? I'm always super curious to see stuff shot with these lenses :)
Yep they'll work fine .
I was actually considering going with their other EOS to OCT 19 converter mount but Cinemods recommended the straight OCT 19 hard mount so I wouldn't have problems with any OCT 19 Lenses on Scarlet or I guess Epic for that matter.
Thanks Mike!
Ev - those are gorgeous shots! What anamorphic lens(s) did you use? Also curious as to how you monitored the anamorphic image and processed it after the fact?
No problem - Ev's also put up images in the Scarlet/Anamorphic thread :)
Thanks Adam and Andy.
These were shot with 50 and 80 squarefronts. Monitoring on the Scarlet is my current issue. I've found 4KHD with a 4:3 frame guide is the best way to work until we see an anamorphic mode with firmware and hopefully a higher vertical resolution. Fingers crossed.
