O'Connor O-Box Mattebox modifications
Steve Sherrick
Boston
I love this mattebox but there are two things I would like for it. A set of masks to control stray light better and the option for metal filter holders. I actually like the plastic ones when I need to go really lightweight but I would like to have metal ones with really tight tolerances for when weight isn't an issue. I may have a source for doing this work but I need to know how much interest is out there for these accessories. Add your name to the list here and if we get enough people I think we can get this done and the mattebox will get that much better.
O-Box mask set
Metal filter holders
Thanks guys!
swing away option please
Yes to the above ..............
PLUS.... I would like to see an adjustable raiser for 60mm spacing on 15 rods raising the MB clear of the rails so the filter tray can rotate freely. I believe this could also open up a new market as well for O Connor which they have already acknowledged in the FF system for still lenses.
Gosh!
Gosh!
At one point I had found a rediculous deal on ebay (obox + ohandles) on ebay, and they went for a whopping $1500. The only reason keeping me from dropping a wad of cash on the O'box was the swing-away option.... I had my eyes on an arri mattebox, but the price is just jaw dropping. (although it is built to last decades)
Another really, really, useful option is to make the adapter to fit, lightweight 15, studio 15, and 19, or lws/19, or essentially a double-edged sword... It seems everyone is moving in the trends of the East Coat/Europe 19mm standards, but, I imagine a lot of us still are on the 15mm bandwagon. Could be helpful.
I'm still in the market for a matte box (the choices nowadays are so massive) it causes my gear-addicted frenzy searches to last waaaay longer than they should, but these are my two cents towards cool gizmo ideas...
Good luck! I'd love to see it, if you make it!! :D
I should probably be clear, as of right now these are the only two modifications/accessories being proposed at this time. No doubt the other issues you guys are bringing up are legitimate with this mattebox, however they are the types of changes that are more likely to be addressed by the manufacturer in future designs. What I'm proposing are more along the lines of accessories that a third party could make to improve certain things with the mattebox. Nonetheless, I will pass along these requests anyway to see if there's anything that can be done.
movcam metal trays fit in the obox from what i gathered looking at them side by side at BH the other day.
Thanks guys!
Did they change the filter holders to plastic? Mine are definitely metal.
I actually had a 15 to 19mm swing away bracket made which works quite well, I'll post some pictures later.
I have 2 O-Box's with 2 sets of trays each (2-4x4 & 2-4x565) and all of them are metal. These were ordered / purchased when O'Connor first announced them, so maybe in the interim they switched to plastic? The 4x4's weigh 68g & the 4x565's weigh 47g
& you can already get 'adapters' to switch between 15LW / 15studio / 19eastcoast.
G.
Oconnor switched to plastic filter holders for the O-box. You can't get metal ones now.
When my Movcam gets back from being on loan, I'll check if the filter holders fit in my Obox. I think somebody actually does make a 15mm swingaway setup that might work on the Obox. The Movcam is surprisingly robust and professional if someone needs a swingaway setup with 15/19 option. Also only about 7oz heavier than the Obox.
And as someone else pointed out, there are 15/19mm options for the Obox, but they are pricey.
heres the short story about this mattebox we were on shooting few weeks ago it was 3 day shooting and we had 3 Red Epic equipped with Angenieux zooms+2 LMB 15 and one O-Box.On the first day tried to shoot van with low loader equipped Foxy Crane sadly from behind while it was going 40mph :) after few attempt we hit the rear end luckily crane entered inside and camera stayed on bumper cuz of cable.thought camera and lens died there :) after checking whats alive i see we lost only one pola filter :) no scratch on camera or lens whatsover.Huge thanks Oconn and O-box from here it saved our angenieux zoom even now Obox is %100 operational and solid as brand new.Its not like waffle arri matteboxes and price is unbeatable.Please trust me and go for it!
One of the filter tie down knobs is a sonafabitch to get to (tiny red knob). Make it longer, bigger. That's the only thing I hate about some of the new OC accessories are fiddly knobs for leprechaun fingers (see OC Follow Focus). Lose the inexplicable rise in the eyebrow. It should be flat period, to maximize what it was designed to do. Perhaps come out with a lightweight for clip on. I find the O'Box a bit too much of a beast for clip on. I know OC would make a clip that could best Arri and for less. Offer some sort of flexible step down ring for still lenses like Chrosziel. Not sure if Chrosziel has the patent on this and if it's even possible to come up with something better. Zacuto universal donut completely missed the boat.
+1 on better stronger knobs for the eyebrow and siders
I use that Chroziel flexi with the O-Box. Works fine.
Agree about the knobs.
Emailed oconnor several times already about the annoying tiny screws, the solution is dead simple, longer and thicker replacement screws. No idea why they don't do anything about it..
Ditto on the screws. And eyebrow, can't fathom the eccentricity except maybe strength. The Chroziel flexi is definitely the best solution with still's glass, I find. Use it on both Movcam and Obox.
Sidewings & sidewing mounts could definitely use improvement.
Screw upgrade request as well. +++1
