Robert Hart
- Feb 26, 2012
Genuine lens technicians will cringe and may well they have good reason, so please, the following comment is me only not any ways near to industry practice.
I operate the SI2K, a digital cinema camera. The Super 16mm film camera lenses that I use on it are slightly out of collimation for a digital sensor which has a fairly thick IR/OLPF panel. It is a little more critical wide wide and ultrawide lenses than for the longer lenses.
After putting it off for far too long, I have procrastinated on this task. I have a great respect for film-camera techs and lens-smiths. Digital cinema cameras make it a little easier in that you see immeidately what you are up to. To correct the lenses for the SI2K, I had to cut some shim material to replace the existing shims or shim stacks which were slightly too thick
Modern plastic shim material can be fiddly difficult stuff to cut tidily if you do not have the proper tools for it.
So if you are rebirthing old motion picture lenses and having to make your shims on the kitchen table, here is a method which might make it a little easier. If I do not have an existing thick and therefore robust shim available as a pattern to cut around, I make a pattern carefully out cereal packet cardboard. Using blue masking tape, I cut thin 4mm strips and tape the pattern down on top of the plastic sheet of shim material. Using a snap-off hobby knife I cut out the centre hole, leaving the strips of masking tape uncut.I then cut the outer edge likewise. I then cut the tapes and shim material beneath through one at a time, moving from cutting one, its partner piece on the opposite side of the circle. This is important to prevent the shim material from creeping or gathering and the cut going bad. I then use good thin haircutter's scizzors to cut the remaining uncut sections of masking tape and shim material around the outside.
Some shims have a small cutout to clear a locating pin. These are you friend as it is possible to link your shim cutouts like the Olympic rings and conserve up to about a third of your shim material. The downside of this is that you do lose the future chance of cutting entire smaller diameter shims from waste trims out of the centres of larger diamete shims.
I found it to be a vexing and timeconsuming task to do it by the suck it and see method of cutting shims, fitting them re-assembling, checking the focus, then taking it all apart, adding or subtracting shim thickness, then doing it all over again.
It is worth doing for the sake of having reliable witness marks on your lens barrel telling truths when they need to be relied upon. This is of course a professional expectation but how many people are having lens techs align the lenses to their cameras or are doing it themselves. There may be more than just a few winging it and relying on the eyepiece and LCD screen.
