The Meizler Module... The Details.
Jarred Land
Fire Chief
Staff member
Shown with EPIC BRAIN ( not included ) installed.
Pre-orders begin September 10th. Ships Mid November.
Meizler Module $13,000
Weight: Aprox. 6 lb
Features:
  • Proxy Recording - Record Proxy files to a RED MINI-MAG card and record REDCODE RAW to side SSD simultaneously.
  • Wireless Motor Control – Integrated Wireless communication between 3[SUP]rd[/SUP] party hand controller and Meizler module. Internal wiring to front outputs for clean cable routing.
  • Wireless Video – Transmit 720p or 1080p uncompressed video at 5Ghz. Wireless video system has <1ms latency.
  • Wireless Audio – Receive audio signals from REDsync Master (optional purchase)
  • Wireless Timecode -Receive wireless timecode from REDsync Master ( optional purchase )
  • 802.11b Compatible – Receive system control commands from custom iPad/iPhone/iTouch app through REDsync system
  • System power is provided by V-Lock IDX battery plate , (IDX and RED data switch), or RED standard 6 pin power port.
  • Smart Hot-Swappable Power supported (battery can be switched when plugged into DC power without shutting camera off)
  • CAN Port – Allows for Hardwired communication between the 3ality Technica hand controller and Meizler module
  • RS232/422 Port – Hardwired communication for iPad, iPhone and iTouch apps and 3[SUP]rd[/SUP] party devices
  • 3D Port – Sync two Meizler modules together to create a 3D lens control system
  • HD-SDI Port – Output HD video
  • REDmote Port – Charges and Communicates with REDmote viadirect hardwire
  • RED Monitor Port – Support Dual RED EVF/LCD operating simultaneously via monitor ports on Meizler and Side SSD. Touchscreen control capability on the RED monitor.
  • Gig-E Port – Master/Slave the RED cameras
  • 4 unregulated AUX power outputs
    • Two 12V output power on right sidecar,
    • One Left side D-tap on battery plate,
    • One Front 3-pin Fischer for Cinetape or other accesories
  • Audio Port – Hardwired 2ch balance audio input
  • Headphone Jack – Outputs audio signals 3.5mm
  • Lens Ports Front
    • Control 3[SUP]rd[/SUP] party lens motors for Focus, Iris and Zoom
  • LEDs
    • STATUS Indicates the Meizler module status state
    • 8.02.11 Indicates the wireless connection for Wireless.
    • PROXY Indicates the proxy recording status to the MINI-MAG
    • THCL Indicates the wireless connection for wireless hand controller
    • WTCL Indicates the wireless connection for wireless timecode
    • WVL Indicates the wireless connection for wireless video
    • FOCUS Indicates the focus motor status
    • IRIS Indicates the iris motor status
    • ZOOM Indicates the zoom motor status
  • Wireless Internal Antennas
    • Interchangeable 6 external antenna module
  • Switch from internal or external timecode
    • Internal timecode – Receive wireless timecode from REDsync Master (optional purchase)
    • External timecode – Receive timecode signal from an external source (i.e Lockit, Denecke and etc) via a BNC and genlock is produced internally
  • Report camera state back to iPad app (optional purchase)
  • Receive sidebar file metadata from REDsync Master (optional purchase)
  • Receive GPS via iOS app (optional purchase)
REDsync Master - $2900
Weight: Aprox. 1lb
Features:
  • RF ISM Band Transceiver 865MHz/915Mhz for wireless audio and timecode
    • Deliver audio stream to multiple devices
  • 802.11b Transceiver
    • Receive and deliver timecode and metadata to multiple devices
    • Able to connect up to 14 devices
  • Supported FPS modes: 23.98, 24, 25, 29.97, 30, 29.97DF, 30DF.
  • Output sync modes: PAL, NTSC, 720p, 720p double frame, 1080i, 1080p, 1080i double frame, 1080p double frame
  • V Sync and H Sync Output to Camera
  • Timecode Output to Camera
  • Timecode output to audio recorder
  • 2 channel guide audio input for RF datalink distribution to camera(s) and other devices
  • Interface to iPad, iPhone & iTouch apps
Physical Interfaces
  • External Power
  • Timecode input
  • Timecode output
  • Output Video Sync
  • 48Khz 16bit audio input
  • Internal Power: 2 x ‘AA’ batteries
HD-SDI Receiver - $3400
Weight : Aprox. 1.3 lb
Features:
  • Any camera can transmit to any combination of up to 4 receivers (HDMI or HD-SDI)
  • Transmission is secure between the camera and receivers.
  • Less than 1ms lag
  • HD-SDI receives up to 200ft away from Camera.
  • 5 external SMA mount.
HDMI Receiver - $1100
Weight: Aprox. 0.5 lb
Features:
  • Secure Transmission secure between the camera and receivers.
  • Less than 1ms lag
  • HDMI receives up to 90ft away from Camera.
  • Internal antennas
Wow. Great looking stuff. Prices ready for release?
A Whole New camera!! That's why I love this company, any other company would release a new product, red allows us to do with hardware what was only possible with software. obsolescence is now just history. Can't wait to see this one at Red Store.
Curt Pair posted about Red Snyc in June glad it's out Now =D
Jarred what about pics of the RED SNYC and the RED SNYC MODULE Heh heh Heh
This looks unbelievable. It's so impressive that you guys were able to fit this amount of functionality into just one module. Awesome work.
As a location sound mixer, I'm curious about the dimensions of the RedSync Master. Also, I'm really hoping that 24kHz audio @ 16 bit is a typo. 48 kHz is kind of the minimum, no?
Proxies on Meizler
Proxies on Meizler
Hi Jarred,
Do you have a timeline by which to expect more details about Proxies on Meizler module?
Thanks,
Sulekh
Its looks bionic, like the EPIC brain's vehicle or something. hehehe
Hi Jared,
Thanks,
Sulekh
I can't tell you all the formats, (except for H.264 and DNxHD) .. but I can tell you some resolutions..
720p - 4:2:2 @ 24 & 60fps
1080p - 4:2:2 @ 24 & 60 fps
2k - 4:2:2 @ 24 & 60fps
2k 4:4:4 will become enabled early 2013.
Different Camera now.
I'm sure that's just a typo. What irks me is that it appears that they're using a 5-pin Lemo connector for audio -- different from the previous Red Epic and different from the TA3 used in the Red One. So this is the third different connector the company has used for sound.
I am glad to see them return to BNC for timecode. And I think a lot of producers will sit up and take notice now that the camera can deliver simultaneous proxies for instant offline editing. This will help eliminate a lot of quibbles from the pro-Alexa front.
Great, looks like a real nice module! , when will there come just a seperate proxy module? Really Need one of those!
looks super.
small questions.
1: will there be a cage for a meizler/epic set up?
2: Is Cmotion supported (or Arri Wireless?)
3: does it bring the epic to a height so no more epic riser is needed?
4: Is there a way to mount the redmote to the dead side in this combo?
5: when is it availble?
6: how big is the range for the Ipad?
thank you!
Please don't say your leaving the whole of Europe out of this?!!!- I was about to order 5.......
720p - 4:2:2 @ 24 & 6 0fps
Can we assume the DNxHD is 10bit and intended or can be used for Broadcast ? Also any Prores 4.2.2 10bit too ?
