Dr. Sassi
If the same distance is given, from a lens to a sensor, the size of the sensor will not and can't change the result of the (same) optic. How would that be possible?
If the distance is the same, the smaller sensor will take only a fraction of the glass that the larger one takes, in that way the resolving power of the lens seems less for the smaller sensor. Seems, as the lens is independent from the size of the sensor of course. Again, there is not communication nor change.
Edit: ... think of it that way, if it would change, than the small core area of an larger sensor would get a different DOF. Sounds not really realistic to me./edit
